Is the Lian-Li PC-7 PLUS Quiet?
Suspended
12 Dec 2005
Leeds
Im looking at a Lian-Li PC-7 PLUS in silver to replace my wavemaster, just want to know if its a quiet case, or quieter thaqn the wavemaster at stock with all stock fans etc
Any case to make quiet you will need to at least mod the fans to make them quiet, 7v usually does the trick.
It is a quiet case, but it always depends what components you put into it.
A noisey graphics card in the wavemaster, will be noisey in the PC7+
currently have a zalman cooler on my gfx card in the wavemaster, and usually have a ac64 on the amd 64 4000 although its dead at the mo, just wondering if the airflow would better with the dual 120mm fans, thus making the case cooler and making sure the ac64 fire up to cool things down less when on cool and quiet mode
It will not make a huge amount of difference as the case you have at the moment is perfectly capeable of keeping your system cool, it will be a case of just tweaking it all a bit to make sure you get the best noise to performance ratio.
Have you thought about getting a T-balancer fan controller?
not thought about that, i thought the 120mm fans would make a better diffrence to the air being pushed out compared to the single rear 80mm fan i have at them mo on the wavemaster, plus im wanting it so i can put a small 4" lcd in the front drivebay, which would look nicer than one on the wavemaster which would be hidden by the door
