Is the MSI® B450M PRO-VDH LED debug pointless?
28 Aug 2014
So my cousin has this motherboard and he got a proper bright white light shining at him after moving his case to tidy up or something. So I looked it up what it meant on his motherboard and it pretty much says - check cpu, ram, gpu etc etc.
So what is the point in this led debug light? It doesn't exactly help find the problem, it just tells you everything you would check if your pc wouldn't post anyway...
This isn't a ask for help thread as its been sorted, he reinstalled the ram and its fine. Just quizzing the usefulness of an LED that says - "it could be anything".
