I was thinking of using the VGA duct on my P180. I took it right out the moment I got the case but was thinking of using it alongside my X1900XT using a Papst 80mm fan blowing on to the card.
Temps are pretty good on the 1900XT 47c idle, although case temps are up a bit cos I have put the fans on low.
All idle.
Also is it worth putting my drives in the bottom chamber? as the vga power cable gets in the way.
All idle.
