Is there a agreed voltage increment?
16 Mar 2012
Chelmsford,Essex,UK
As title says I think,I read somewhere someone was using 0.06 but not sure, what do people think? Is there a logical increment that you should use?
Thanks
I just put the core voltage slider (in AB) to the level I want to try.
Example I just moved mine from 1.031 to 1.081.
For my EVGA 580 SC, I've found I can only increase voltage in pre-defined steps of around 10 mV using both Precision X and Afterburner. The available voltages must depend on the card.
Just increase by whatever you feel comfortable doing - just watch your temperatures.
Yeah I did know that you couldn't use certain voltages like if I type in 1180mv it jumps to 1181 mv, so I tried every number between 1175mv and 1180 mv and the next step from 1174mv is 1181mv so yeah just relised there are certain increments you have to use.
Regards
