Is there a better deal than this £125 mobo cpu bundle?
8 Jul 2005
For £10 more you can get a X4 955BE which overclocks quite well if that's something you're interested in,
http://www.overclockers.co.uk/showproduct.php?prodid=cp-244-am&groupid=701&catid=6&subcat=1943
http://www.overclockers.co.uk/showproduct.php?prodid=mb-466-as&groupid=701&catid=1903&subcat=1481
£136.99
this shows the x4 840 against a x4 945 which i believe is essentially a 955 with a lower clock speed (3.0ghz instead of 3.2ghz on the 955).
http://www.techpowerup.com/reviews/amd/phenom_ii_x4_840/9.html
hmmm so either the cheaper 850 or the pricier 2120
guess gta4 would go better on the 2120
what's the cheapest non Crap mobo for either?
looks like I am heading to Intel, which is a surprise
ok then prob a daft question but does a matx mobo fit in an antec atx case? and therefore I don't have to worry about the board form factor as long as it has enough sockets and ports
if the case is ATX then an mATX board will fit. mATX is exactly the same as an ATX board with the bottom three expansion slots chopped off. even the mounting holes are the same.
if the case has 7 expansion slots at the back then it will fit in pretty much any motherboard (there are some exceptions, but these will be very expensive)
I suspect i know the answer but is a llano worth considering?
Or should i just try to stretch the budget (or search MM etc) and just go for the i3 2100 option
ok fine, you have worn me down, AMD no more, i will squeeze the bugdet and go for the i3.
In fact i managed to sell an old linksys router, two 60gb IDE drives for a total of £30 which might just make up the difference.
Is there a noticeable difference between 1600 and 1033 ddr3 ram? The cheaper mobos have the slower rated ram but i am wondering if i can just ignore that.
You can ignore the ram rating, currently that kingston 1600mhz for twenty quid is a bargain.
Just use the stuff you already got.
And finally for tonight, if i go for the i3, i cannot overclock, so the stock cooler that it comes with should be fine, do i even need to consider replacing it with something else?
