I understand that they are different thicknesses but the description states one requires 'side by side' 120mm fan ports and the other requires 'adjacent' 120mm fan ports.
To me this sounds like the same thing but i just want to make sure there is no subtly difference that I am unaware of before making a purchase.
Here is the image,
http://imgur.com/a/ylblP
Also, while I am here I should ask which of the two you would recommend and why? I'm planning to use it to cool my GPU and mount it to the front of a H440.
Thanks for your help
Here is the image,
