Hi,
I have an MSI HD7870 Black Knight Edition that I believe may have developed a fault; it has become exceptionally noisey of late, due to extremely high rpm speeds, even at low load. I have been using GPU-Z to track its fan speed, temperature and fan rpm, and have noticed that when idling the fan runs at 30% and ~1200rpm. When gaming, both the AMD Catalyst Control Centre and GPU-Z report that the fans are running at 40% load, and temperatures are averaging 57'C (max temperature was 69'C so still well below a 'high' temperature for a GPU, Im sure you'll agree) - the problem is, the fans are at ~4400rpm. There are occasions where my fan has hit 60%, whereby I can literally hear my PC from 2 storeys down.
I am unsure as to whether the following is part of the issue or just how the cards are set, but at a 0% load the fans are still running at 30% and ~1200rpm - I would have though, and have seen in other cards of mine, that at idle, the fans drop to much lower rpms.
Would anyone be able to advise as to whether this is a fault, or merely the way these particular cards are set up?
Kind regards,
Cookeh
Kind regards,
Cookeh
