Hi All,
Does anyone know if there is a fix for this issue. When i restart the screen is fine for about a second then goes to horizontal coloured lines with a 1 inch white bar scrolling down the page. Occasionally it nearly clears but reverts back.
If i plug in a monitor via hdmi (it's a 2013 13" Macbook Pro) it's fine on the monitor and eventually the lines clear on the Macbook but it continues to flicker slightly.
Thank you
Mark
Thank you
Mark
