Is there a formula in Excel that identifies capital letters and inserts a space?
Caporegime
13 May 2003
Warwickshire
Hi y'all
If I have a load of names that someone had brilliantly removed the spaces from (but that still had the upper case letters in them), how would I go about automatically inserting a space before each capital using formulae?
I'm thinking along the lines of FIND, UPPER, SEARCH etc but I can't get it to work.
For example, convert
JohnSmith
SusanJones
into
John Smith
Susan Jones
without having to do F2 space enter hundreds of times! Many thanks :).
Hi |Robbie,
I Reckon the easiest way, for a one-off would be:
Edit, replace
A
A
Replace All
B
B
Replace All
etc
Now the first name in the cell will start with a space.
If all the names are in column A then in Column B
=Trim(A1)
Then copy and PasteSpecial to values.
If you are going to have to repeat this then put the macro recorder on...
Hi Namsnik and thanks for the reply.
However, I'm struggling with your solution. Replacing A, B, etc. with what?
And if I wanted the first name in each cell to start with a space, I would just do =(A1&" "). And even when the first name starts with a space, I don't see how that would help me split the first name and the surname?
i think he means
replace A with (space) A
26 times
but thats not ideal as it will put a space at the front of peoples names
EDIT: Namsnik solved that, good lateral thinking there
you could use the macro recorder and assign the thing to F11 or F12, and just hold it down untill its finished?
