Is there a good head set that connect using a 3.5mm jack
27 Sep 2009
I have a logitech Z4 and you can plug in a head set using the 3.5mm jack on the control pod. I cant seem to find any on ocuk. I willing to pay up to £25
Also was just wondering where is the best place to put a sub. On the table, under the table etc...
thanks
thanks
Iirc your ears can't tell which direction bass sounds come from, so you can put it anywhere in the room. Although I wouldn't put your sub on your desk as you will feel the vibrations and I wouldn't put it on or next to your case either.
My sub is on the bottom shelf of the shelving unit next to my desk.
thanks ive put it under my desk
