Deleted member 209350
OP
Is there any reason why you need dual Gigabit LAN ports? Does it require teaming support?
Bare in mind both local connections and internet speeds are advertised as bit, so a single gigabit port will still be more than faster than Virgin's fastest package. In your case, Virgin's 250mb package is still 4 times slower than gigabit LAN. The only time you will require faster LAN to keep up with internet speeds is if you have a FTTP 1 gb/s+ service.
You're getting mixed up with Virgin's service as megabyte. You're getting 110mb on a 100mb service because Virgin boosted it slightly so they can still advertise it as 100mb due to advertising rules. It's still no where near saturating a gigabit port.
I didnt meant dual gigabit lan ports, I meant a lan port that can support upto 2gigabit speeds! Also I was under the assumption that a gigabit lan port may only be able to handle upto 125mb speeds? If thats not the case, then 1 gigabit lan port is more than enough
