Is there a RAM stick that has similar LED effect like old Ballistix Tracers?
13 Feb 2008
Glasgow
You know, those separate leds and effects you can set so they blink in different configurations.
All those new LED RAM I see are ugly AF, with those diffusers.
I used to use those, but the M.O.D software didn't play well with X99 boards for some stupid reason and Crucial's engineers didn't give a **** about fixing it. I ended up using Asus's software to control the RAM instead.
The closest I've found is Corsair Dominator, which is a little diffused, but still has the lights looking like individual points rather than a rainbowed gradient. The top has ugly 'DOMINATOR' text in the middle, but the sides are clean slotted openings. It works well enough for the effects I like and iCue can even be uninstalled once you've set up the RAM however you want.
Thanks, just checked those out, I know what you mean by those separate leds thing. Shame they put their name on it, instead of making whole length in squares, you're right.
