If I sat down to think of a worse way of securing a fan to a heatsink than those clips, I'd have a job doing so.
I've actually failed to be able to get the fan attached to a True Spirit 140 Power. You can't put the fan on until after the cooler is attached to the motherboard (a screw is under the fan) and I can't get the bottom end of one of the clips in. I can't see a thing because it's near the motherboard and obscured.
I decided to take a break from it when I was starting to consider drilling holes in the heatsink and bolting the damned fan on
I've always found them a problem. Am I missing something obvious?
I'm referring to this sort of thing:
https://www.overclockers.co.uk/prolimatech-genesis-140mm-x-25mm-fan-clips-hs-043-pl.html
The shape's slightly different for the True Spirit 140 Power, but the basic horrible idea is the same.
