Is there any mounting difference for 1150 and 1151 ek CPU blocks
20 Oct 2014
Hi all I inherited a watercooling set up from a friend second hand and now feel the need to upgrade to the new coffee lake 1151 with the z370 390 motherboards. It's a ek water block on but I have no clue what model other than it fits my current motherboard. So if I want to change do u need a new block or would the one I have work fine
Thanks
Excellent I thought the hole spacing looked about the same but was more concerned about the height of the CPU when seated in board incase the block is fully locked down but actually in fresh air above CPU by a fraction so the the 4 mounting bolts are exactly the same length for all the Intel boards.
Cheers
