Hi, I’m planing a new build and would like some advice please.
I am planing on getting 32GB of ddr5 for my future build, is there any problem if I buy first a kit of 2 sticks of 8GB each and then down the line buy another kit of 2 sticks of 8GB each? Or should I save the money first and go and buy a kit of 4x8GB each?
Is there a difference in buying one pack of four RAM sticks instead of two packs of two sticks?
Is there any issues with compatibility or it will be ok if the second kit is the same specifications of the first kit?
Thanks
Thanks
