- 2 May 2011
- Woking
I'm doing a couple of things to make my wife feel a little more secure at home. With the weather as it is recently, we often have the fan on and then you can't hear any disturbances downstairs.
For the front door, I'm putting on a couple of bolts, which should make it harder to break open if someone does get through the lock. At the back, I can't do that because of the design of the french windows.
For some reason, the back has a lock on both the inside and outside. The reality is that I will never use that door to enter the house. So I'm wondering if I can take away the cylinder on the outside so that it's not possible to pick that lock.
It looks like this:
I have found this device which is sort of like the old school steering wheel lock, but for french windows. That might be a better solution, but maybe not.
Just one thought I had - on the front door we have a thumb turn thing to lock it from inside. That would equally be fine on the back, but I don't know if I can get one with a blank on the other side still...
It looks like this:
