- 2 Mar 2009
I'm looking through the configs but cant find anything! i want to set the framerate to 30
lol@everyone suggesting vsync, despite the fact that that'd only lock the frame rate at 60
lol at that fact, except everyone suggesting it full well knows it will only lock to a framerate if you are currently producing MORE than that number. otherwise it locks to a lower framerate at intervals, if you have less than 60fps it will lock at 30.
Erm, I've never seen a game do thislol at that fact, except everyone suggesting it full well knows it will only lock to a framerate if you are currently producing MORE than that number. otherwise it locks to a lower framerate at intervals, if you have less than 60fps it will lock at 30.
Vsync locks the framerate at factors of 60 (assuming you have a 60hz monitor).
For example, if your system can pull 80fps in a particular scene, it will lock the fps at 60, if in another scene you can only pull 45fps, then it will lock at 30fps, if you can only manage 25 fps it will lock at 20fps and so on.
While vsync will cap the displayed framerate to your monitor refresh (eg 60fps at 60hz), the rest of your statement is just inaccurate.
If your PC can render a game at 45fps, then you will get 45fps - it won't lock at 30fps. In that case, in one second's worth of update, you'd be getting something like 30 frames that will each render within approx 16ms (at 60fps, 1 frame has just over 16ms to complete), and 15 frames that could take anything up to 32ms each.
