Is there anything I can get to improve my current PC?
7 Mar 2006
Basically at the moment it's a:
AMD Athlon X2 3800+
Asus A8N-E Motherboard
2gb DDR RAM
Two hard drives, one 40gb, one 80gb. I think they are both maxtor. Pretty old though.
Radeon X1800XT 256mb
What's my best thing to do for the best ratio of price to improvement, or should I just leave it as it is. Mainly I want to play Oblivion.
Liggs said:
{snip}Two hard drives, one 40gb, one 80gb. I think they are both maxtor. Pretty old though{snip}
Loose the Maxtor & pick up a Seagate 7200.10. My Maxtor's started acting up lately :( You can use them for back-up & that's what mine is doing, but for day-to-day use don't trust them!
That system is still pretty good! To be honest, I would just hang fire now until Vista is released and DX10 cards are available. Then treat yourself to a whole new shabangle of a system.
ask yourself the one important question, does it play oblivion already to an acceptable standard? if yes then leave it :)
if the answer is no then id wonder why tbh as thats a more than decent enough spec PC to play it really, ok i would agree with #2 comment, maybe the hdd's are a bit aged, especially as you can pick up a very good 250gig+ sata2 drive for a really decent price, that would probably affect loading times from hdd a lot from what you have currently
A new hard drive is about the only thing I'd consider spending money on as it is about all you could transfer to a new system, as hp7909 says the 7200.10 range are good and very quick.
You could always overclock what you have which would give you a decent boost. You may have to get a decent cpu cooler if you only have the stock one. That should give you lower temps and hopefully be a bit/lot quieter.
Re:
To be honest I've got a pretty good processor, but I haven't got the first clue about overclocking anything. I've tried to learn but I can't seem to understand it. I'm not dumb with computers or anything, maybe I'm just looking in the wrong place.
I think I'll get a couple of new hard drives though, as you said.
A fast hardrive helps in Oblivion without doubt, when galloping on a horse thru woods or grasslands then the drive has to keep snatching data as you go along & you can get hesitations & stuttering regardless of your graphic card etc. With tweaking I have all but totally eliminated this .
I have Oblivion loaded on both my drives, a 74gig raptor & a maxtor 80
& the raptor is a heck of a lot better for games that need constant access to the drive without a doubt .
