is there no decent fan recommendations thread ?
Caporegime
1 Jun 2006
Notts
looking across forums couldn't find any decent threads on just fans.they are obviously important.yet there isn't many reviews or recommendations yet there is a big variety.
maybe a subsection or sticky with sizes,brands,quietness,cooling
What are they going to be used for?
front intake of case currently have 2 x 140mm nzxt fans which i want to replace with decent fans. prefer silence or least amount of noise.
Morning dg l use Asus Suite 3 and only install the options l need, once you have ran the 5-Way Optimization then you can set the speed of your fans to what you want with fan expert 3, works a treat not had any trouble at all..
My 3x140+1x120 pwm fan are controlled by fan expert 3.
