is there something wrong here, ocz 1600mhz
16 Dec 2008
Lincolnshire
just built this i5 system up, not changed any setting in bios yet, but was wondering if my memory is right, model numbers dont match at all, neither does speed:confused:
Anything above 1333 or 1066, not sure, is classed as an overclock so you will have to set it yourself in the BIOS.
Wouldnt be able to tell you about the model number.
The speed will need to be changed manually in the BIOS, part number could be a revision update.
its looking like anything above 1066 is classed as a overclock, also my bios has 3 4 5 for setting the memory (not sure of the exact term) but it only changes memory to 1333mhz max, no where is there an option for 1600mhz
OCZ3P1600LV4GK is the 4GB kit made up of 2x OCZ3P1600LV2G sticks...
The 4G and the K means 4Gb Kit, the 2G means 2GB stick.
Simples :D
