Hi OCUK community,
I'm having a bit of a mare with my rig at the moment, see specs below;
Microsoft Windows 10 Professional
Intel Core i7-8700K
ASUS TUF Z370-PRO GAMING Latest Bios 2102
Noctua NH-U12S with 2 fans
Superflower 1000W Platinum
2 x Corsair CMR16GX4M2C3000C15 8192 per stick
Sapphire 5700XT Nitro
EVGA Nu Audio Soundcard
Samsung Electronics SSD 960 NVMe PCIe SSD
Samsung SSD 850 EVO 1TB
I have been running it at default settings, so flash new bios, clr CMOS with Jumper, Set it to XMP and configure fan profile and onboard devices. Now I installed Hardware Info for the first time and I noticed on desktop my core voltage was showing vcore 1.5. All C states are on, Balanced power profile in windows etc. So I installed AI Suite just to see what it reported and it was the same as Hardware Info. Then I tried CPU-ID, Aida 64, all the same. So I reset bios (I must add vcore in windows is 1.136) , basic configuration again and booted into windows. It started off at 1.3vcore, then hit 1.5 again then crept down to 1.35.
I decided to format and do a minimal install just in case something was messing things up, same result. I must add, temps seem ok, 35oC at the mo and the vcore is 1.344.
I decided to try and set it manually and also all cores at 47 as the default is per core. After watching many videos including der8auer's tutorial I decided to try to get it stable at 47. I'd be happy with that but for some reason my system just wont go there. I can boot into windows no problem but OCCT and Prime both fail. I set the vcore manually and I thought I would start with 1.3. Instant fail on all stress tests so I tried 1.32, didn't fail as quick but still failed. Went to 1.35, lasted and hour this time then failed. Went up to 1.38, 2 hours in then fail. I must add Temps are still ok even in the midst of torture testing. I'm reading people getting 4.9 on air at 1.32 - 1.35!!! Have I just got a dog of a chip do you think? I have tried alternative memory as I have some here, made no difference. I have ordered a new PSU form OCUK not that it will make any difference??? Could it? I've ordered it because my Leadtek is so bloody big I wanted a smaller one, not specifically because of this issue.
Any advice much appreciated.
Intel Core i7-8700K
