I know, but I'm looking for a solution that takes up as little desk space and has as little wiring as possible.
My dilemma is that I already have a decent monitor that could be used - a Dell U2312.
You can get a sound bar for this.
But then I'm not sure how to do the connectivity.
I want an XBox connected permanently and free wires to connect a Laptop as required.
The U2312 has two inputs VGA and DVI which are both video only. I'm not sure whether these can be connected at the same time and you just switch between them. Alternatively, I could use an HDMI auto switcher with an HDMI<>DVI-D adapator but that only sorts out the audio.
With the sound bar, the monitor powers it but it has a 3.5 mm stero jack on a lead for input. If we were just talking one source that would be easy but I have both an XBox and a Laptop.
I suppose if I could make sure only one was on at a time I could use a Y-Lead, but what would happen if they were both one - would the two audios simply be mixed or could it cause damage. Besides it is getting a bit messy at this point.
Cheers,
Nigel
