I would go 5800X or if budget is tight then a 5600X or a 10700K.Would an AMD Ryzen 7 3700X be good?
1920 x 1080pI would go 5800X or if budget is tight then a 5600X or a 10700K.
Which resolution / refresh rate will you be playing at?
And what are you looking to spend?
I'd stick with your original build then if it's around that price as I doubt you'll get anything better for the money.1920 x 1080p
144 Hz
i’m looking to spend around £1000-£1100
thank you for your helpI'd stick with your original build then if it's around that price as I doubt you'll get anything better for the money.
Completely overpriced for 5600X, for which £30 level coolers are perfectly fine.CPU Cooling - Cooler Master MASTERLIQUID ML240L RGB V2 65.59 CFM Liquid CPU Cooler
G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory
SSD/HD - Samsung 860 Evo 500 GB M.2-2280 Solid State Drive +
Power Supply - Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply
