Is this a GPU problem?
12 Dec 2009
Gloucester, UK
Hey guys,
Recently got my two 290s and one of them (the boxes that is) was damaged. Looked like it had been thrown around a bit and crushed, so I put the one I was worried about in my old rig, just to test.
Upon booting, where i would usually see my mobo screen graphic, I see this:
Should I be worried? Or is this more likely a problem elsewhere? After this, the system boots up fine and I can't see any display problems. I've tried running a few games and all seems ok.. I don't get great performance but then this is a really old rig that will be bottlenecking the 290 to hell.
Update****
Ive updated bios and made sure all windows display drivers up to date. Still see this upon booting.. Why would i be seeing the motherboard graphic?
Will continue to play around tonight.
Does it happen using a different connection from what you're using now? For example if using HDMI try a DVI connection etc. Does it still occur if you disable the bios logo screen?
Ive tried both types of connector, still the same. Though i will try disable the logo screen if i can find out how on this mobo.
I mean its an extremely old mobo so im banking on it just being this crappy old thing. At the moment its all i can test them on.
The fact it happens with both cards is sort of reassuring, as i dont think its the cards themselves. But id def like to find out why its happening so ill have another play tonight.
I expect it's just the mobo tbh mate.
Hopefully if all goes to plan ill have my new case Monday. Then i can start getting down n dirty.
