Hi , i have just put together a new build but i am having real problems doing a clean install of the Windows 10 operating system . The install keeps failing at the second stage between 20% and 45% usually with a blue screen but with varying different stop codes e.g
IRQL NOT LESS OR EQUAL
KERNAL SECURITY CHECK FAILURE
SYSTEM SERVICE EXCEPTION
MEMORY CACHE
The build is
GIGABYTE AORUS ELITE X570 with bios q flashed to f11
CPU AMD RYZEN 5 3600X
POWER COLOR RADEON RX 590 RED DRAGON
PATRIOT VIPER STEEL 16gb ( 2x8gb) dual channel ddr4 3600mhz
M2 SAMSUNG 500GB 970 EVO PLUS
650W SEASONIC PLATINUM POWER SUPPLY
NXT H510i MIDI TOWER CASE
The install disc is from genuine windows 10 home purchased at overclockers and i have also tried a downloaded usb install from microsoft so unless both are corrupted it surely cannot be software .
I was trying to install on a new M2 nvme 500gb samsung 970 evo plus but also tried a 120gb ssd sata drive with same results with only one of these drives connected in at any one time .
I think i have set up the memory correctly and is showing in bios xmp profile 1 as correct ram speed and capacity . Is there something i could have missed as its been a while since i did a build and things seem to have moved on at a pace .
Any help would be much appreciated .
MEMORY CACHE
The build is
