- 1 May 2011
- Blackburn, England
Ok This is my first post so I'm sorry if i make any Mistakes ok
I have this problem when i boot my system & after an hour the windows load in section, First the main window & then bits of the program interface loads bit by bit. Sometime rendering black & white, first i thought it may of been my 450GT display card so i took it back & got a brand new GTX 460 SE. Anyway it still happened; so this time i got brand new Kingston RAM 4GB it was OK for about a week & then Wam there it happens again
Ok so New drivers up to date,windows is up-to date, Daily scans with EST online scanner & Malwarebytes, Nothing found apart from cookies, even the Intel E6500 is only 3 months old if that. But as you can see, it is clocked But nothing is over done & it's in limits & waaay below the average temps.
I hope some one here will be able to help attached a file from system info with this post also. If anything else is needed please let me know.
I also play an online game called Secondlife i use the Phoenix Viewer to log on to that game,& the rendering in the game is ok until an hour later & that's it all the opening problems get worse, have playing this game now for 2 years & never ever seen anything like this before, am stumped...
Ran MemTEST for 6 hours everything is OK. All PASSES no ERROR's
So I'm thinking could this be a conflict somewhere?
PLUS ALSO ran the Intel chip test
Ok Just an Update Also Just Ran the Intel Processor Diagnostic Tool Everything is A'ok.
Ok so here are the screen shoots of the problem & CPUz
1st the problems & timings
http://www.flickr.com/photos/artificial-intelligence/5678871168/in/photostream
http://www.flickr.com/photos/artificial-intelligence/5678871300/in/photostream
http://www.flickr.com/photos/artificial-intelligence/5678312305/in/photostream
http://www.flickr.com/photos/artificial-intelligence/5678312729/in/photostream
http://www.flickr.com/photos/artificial-intelligence/5678873012/in/photostream
http://www.flickr.com/photos/artificial-intelligence/5678334801/in/photostream
The Power Supply is a OCZ technology Stealth X Stream2; 700W With Multi GPU Ready.
NVIDIA System Information report created on: 05/02/2011 06:51:09
System name: GARY-PC
[Display]
Operating System: Windows 7 Ultimate, 32-bit (Service Pack 1)
DirectX version: 11.0
GPU processor: GeForce GTX 460 SE
Driver version: 270.61
DirectX support: 11
CUDA Cores: 288
Core clock: 802 MHz
Shader clock: 1604 MHz
Memory clock: 1905 MHz (3810 MHz data rate)
Memory interface: 256-bit
Total available graphics memory: 2431 MB
Dedicated video memory: 1024 MB GDDR5
System video memory: 0 MB
Shared system memory: 1407 MB
Video BIOS version: 70.04.2E.00.A0
IRQ: 16
Bus: PCI Express x16
[Components]
nvui.dll 7.17.12.7061 NVIDIA User Experience Driver Component
nvxdsync.exe 7.17.12.7061 NVIDIA User Experience Driver Component
nvxdplcy.dll 7.17.12.7061 NVIDIA User Experience Driver Component
nvxdbat.dll 7.17.12.7061 NVIDIA User Experience Driver Component
nvxdapix.dll 7.17.12.7061 NVIDIA User Experience Driver Component
NVCPL.DLL 7.17.12.7061 NVIDIA Compatible Windows Vista Display driver, Version 270.61
nvCplUIR.dll 3.6.750.0 NVIDIA Control Panel
nvCplUI.exe 3.6.750.0 NVIDIA Control Panel
nvWSSR.dll 6.14.12.7061 NVIDIA Workstation Server
nvWSS.dll 6.14.12.7061 NVIDIA Workstation Server
nvViTvSR.dll 6.14.12.7061 NVIDIA Video Server
nvViTvS.dll 6.14.12.7061 NVIDIA Video Server
NVSTVIEW.EXE 7.17.12.7061 NVIDIA GeForce 3D Vision
NVSTTEST.EXE 7.17.12.7061 NVIDIA 3D Vision Test Application
NVSTRES.DLL 7.17.12.7061 NVIDIA 3D Vision Module (0)
nvDispSR.dll 6.14.12.7061 NVIDIA Display Server
NVMCTRAY.DLL 8.17.12.7061 NVIDIA Media Center Library
nvDispS.dll 6.14.12.7061 NVIDIA Display Server
PhysX 09.10.0514 NVIDIA PhysX
NVCUDA.DLL 8.17.12.7061 NVIDIA CUDA 4.0.1 driver
nvGameSR.dll 6.14.12.7061 NVIDIA 3D Settings Server
nvGameS.dll 6.14.12.7061 NVIDIA 3D Settings Server
CPU TEST
--- IPDT - rev 1.25.0.0 ---
--- Start Time: 05/02/2011 05:27:23---
--- Skipping Config ---
--- Reading CPU Manufacturer ---
Expected --> GenuineIntel
Detected --> GenuineIntel
Found --- Genuine Intel Processor ---
--- Temperature Test ---
Temperature Test Passed!!!
Temperature = 54 degrees C below maximum.
--- Reading Brand String ---
Detected Brand String:
Pentium Dual-Core E6500 2.93GHz
Brand String Test Passed!!!
--- Reading CPU Frequency ---
Expected CPU Frequency is --> 2.93
Detected CPU Frequency is --> 3.66297
CPU Frequency Test Passed with Warning!!!
The processor frequency could be affected by over-clocking or power management
features. Intel(R) does not support over-clocking of its processors.
Over-clocking is not compatible with the Intel(R) Processor Diagnostic Tool.
In order to ensure the processor frequency is not affected by these, please
enter BIOS and load defaults and disable any 'Over-Clocking' or power
management features that may be affecting processor frequency. Also please set
any software applications which control power management features to default.
--- Reading FSB ---
Expected FSB : --> 1067
Detected) FSB : --> 1067
CPU FSB Test Passed!!!
--- Running Base Clock test ---
--- This CPU does not support base clock test ---
--- Running Floating Point test ---
Million Floating Points per Second, MFLOPS --> 403.2
Floating Point Test Pass ---
--- Running Prime Number Generation Test ---
Operation Per Second--> 1.99374e+006
Prime Number Generation Test Pass ---
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 2 x 32
- Detected L1 Inst Cache Size --> 2 x 32
- Detected L2 Cache Size --> 2048
- Detected L3 Cache Size --> Not Detected.
Cache Size Test Passed!!!
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX/SSE/SSE2/SSE3/SSSE3/SSE4.1/SSE4.2 ---
MMX - Intel MMX Technology Feature Supported --> Yes---> PASS
SSE - Streaming SIMD Extensions Feature Supported --> Yes---> PASS
SSE2 - Streaming SIMD Extensions 2 Feature Supported --> Yes---> PASS
SSE3 - Streaming SIMD Extensions 3 Feature Supported --> Yes---> PASS
SSSE3 - Supplemented SSE 3 Feature Supported --> Yes---> PASS
SSE4.1 - Streaming SIMD Extensions 4.1 Feature Supported --> No ---> No Test Required
SSE4.2 - Streaming SIMD Extensions 4.2 Feature Supported --> No ---> No Test Required
Test Cycle Count = 100
--- MMX_SSE - capabilities check complete ---
Pass --- MMX - SSE Testing complete ---
..Query 4..
--- Querying for Intel(R) Integrated Graphics Device (IGD) ---
..Intel(R) Integrated Graphics Device not supported on this processor..
..Skipping Intel(R) Integrated Graphics Device Presence Test..
--- IMC NOT Supported on this Processor ---
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
Temperature = 65 degrees C below maximum.
--- Test End Time: 05/02/2011 05:31:22---
UPDATE
Flashed the BIOS & updated it,as it was out of date still seeing these problems but not as bad, Still have black blobs after an hour or so of using, but it as help the matter some what,
Ok so if i have posted in the wrong place am sorry, this is my first post here.
Am running an Windows7 32Bit System also. This is my first attempt at clocking but been reading many posts here for months now
Btw Great works you do here guys.
[Display]
DirectX support: 11
CUDA Cores: 288
Core clock: 802 MHz
IRQ: 16
[Components]
CPU TEST
--- Reading FSB ---
..Query 4..
--- CPU Load ---
--- Load Level = 8
CPU Load Passed!!!
UPDATE
