I have a second computer which only gets used a couple of times a week, and spends the rest of the time switched off. Yesterday, I powered it on and and it started up, but the screen never came on. I shut it down, switched off the mains, cleared the capacitors, then tried again. This time it booted without issue. It needed to update a driver, so I told it to reboot. Again, the screen failed to start up. I also noticed that HDD light was off.
After a series of reboots, none of which got beyond the BIOS screen, and most of which failed to get that far, what I noticed was that
a) Sometimes everything is running, but the boot has clearly stalled. Again, the HDD light does not flash, except briefly when it powers on. This board does not have LEDs to tell you the boot stage.
b) Sometimes the fans on the GFX card and the water pumps slow down and stop after about five seconds, but everything else stays on. This includes the lights on the GFX, and all the case fans. A couple of case fans drive off the motherboard, the rest off off a molex-connected fan controller.
c) I cleared CMOS (in case it was an o/c issue) and managed to get into BIOS. The trouble is, the boot will only go into BIOS: when you tell it to continue, it actually reboots, which means another failed boot. But I seriously doubt this was anything to do with the overclock. And this trick often fails, with the boot stalling long before the BIOS screen.
The other likely cause, the PSU, is about five years old, and more than enough power for the job. But in my experience PSUs tend to just go bang.
Specs are:
Intel i5820K - was at @ 43 x 100 (4.3GHz), now at BIOS default
Swiftech H20-320 w/c kit, with Apogee GTZ block
MSI X99A Krait Edition
4 x 4GB Corsair Vengeance PC4-25600 3200MHz RAM
EVGA GTX980Ti Superclocked
500GB Samsung 860 EVO SSD
2 x Seagate Barracuda 2TB 7200 HDD in RAID 1
Corsair Obsidian 800D, Corsair HX1200i PSU
MY feeling is that this either PSU or motherboard. Unfortunately I don't have a spare of either I can easily test with, and both are expensive items to buy if they turn out to be un-needed.
The PSU is modular, so I'll try different sockets and see what happens. That at least I can doo without expense. But my feeling is that this is motherboard. Does this seem reasonable?
Specs are:
