- 9 Mar 2007
Hi all, wasn’t really sure where to post this, but General Hardware should be ok. For about 5 or 6 months now, when my computer goes into sleep mode, this problem seems to happen about once every couple of weeks or so. Whenever I press the power button to switch the computer back on, it won’t turn on. I can try for 10 minutes pushing the button, before it eventually comes back on. I then have absolutely no more problems with it, until it decides to do the same thing a few weeks later.
I was originally running Vista Ultimate, until Windows 7 Beta came out in January, and the problem has occurred on both. My system runs at stock settings.
Question is do you think it’s a problem with my PSU, Motherboard or something else. I have checked all the cables for PSU and case wiring to the motherboard and everything seems to be ok.
Thanks for all your help in advance.
This is my setup
Hiper Type-R PSU
Gigabyte P35 DS4 with F13 Firmware
E6750
Arctic Cooling Freezer 7 Pro
4gb PC2-6400 OCZ Platinum Rev. 2
Asus 8800gt
This is my setup
Hiper Type-R PSU
E6750
Asus 8800gt
