Is this a serious problem?
27 Nov 2003
Loughborough
I recently put together a Ryzen system for some light rendering work with -
AMD Ryzen 3 1300X
Gigabyte GA-AB350M
HyperX Fury Black 8GB (4GB x2) DDR4 2133MHz CL 14
Aerocool Integrator 700W 80+
Gigabyte RX560 OC Edition 4Gb
And it seems fine most of the time... well a bit buggy perhaps, mostly with GPU crashes.
I run a dual-screen setup and periodically this happens -
I'm running Crimson ReLive 17.11.2 with no updates available, are there still kinks being worked out with drivers or do I have an actual issue somewhere?
Hiya,
It's just one normally, and it's the secondary.
I'm wondering if it is some kind of wake bug.
i think it may be related to 2d and 3d clocks getting stuck perhaps, i presume a reboot normally resolves this issue? would most definitely try a DDU and reinstall the latest drivers.
Is this after resume from monitor standby / sleep on Windows 10, using a DVI-HDMI cable? If you force the monitor to re-scan inputs does the issue fix itself?
