Is this a solid entry gamer build for my roomate?
3 Feb 2010
Behind you
My room-mate is looking towards entering the gaming market and knows the investment. I was looking at a few skylake builds but i wasn't convinced with the speed vs cost compared to the older chips. He would want something that 1) looks decent 2) is reasonably quiet and 3) plays anything at 60fps @1080p. Mouse/keyboard/monitor not required.
This is what i came back with, any advice on what to swap-out would be appreciated. (he collects blu-rays so the optical drive is required)
*Updated*
YOUR BASKET
1 x EVGA GeForce GTX 970 SSC rev2.00 ACX 2.0 4096MB GDDR5 PCI-Express Graphics Card (04G-P4-3975-KR) £299.99
1 x Gigabyte Z97X-SLI - Devils Canyon Core i5 4690K Bundle **£12 Saving** £263.98
1 x Fractal Design Define R4 Midi Tower Case - Black Window £79.99
1 x Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139) £79.99
1 x Crucial BX100 250GB SSD SATA 6Gbps 7mm Solid State Drive (CT250BX100SSD1) £79.99
1 x Corsair Hydro H90 140mm High Performance Liquid CPU Cooler (CW-9060013-WW) £76.99
1 x Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Memory Kit (CMY8GX3M2A2133C11R) £67.99
1 x SuperFlower Golden Green HX 550W "80 Plus Gold" Power Supply - Black £59.99
1 x LG WH14NS40 Blu-ray Writer Optical Drive 14X BDR £48.95
1 x Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003) £41.99
Total : £1,099.85 (includes shipping : Ex.VAT).
Be mindful though I'm not sure how the 140 rad will fit , should be ok though....should :)
would "bottom 1" or "top 2" be an option for the rad?
Cooling system
Front: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed; 1 - 120/140mm fan (not included)
Rear: 1 - 120/140mm fan (included is a hydraulic bearing 140mm Silent Series R2 fan, 1000 RPM speed)
Top: 2 - 120/140mm fans (not included) - positions also support some models of 240mm radiators, depending on configuration
Bottom: 1 - 120/140mm fan (not included)
Fan controller: 1 - Integrated fan controller for up to 3 fans (included)
