Is this a thing : Bluetooth Act As USB
15 Aug 2011
I am just wondering if this is a thing, and where to get it from.
I have a particular piece o equipment that connects via USB. Being part of a steering wheel, hat kinda sucks as it tends to catch every so often.
Is there something out there that can mimic the USB connection via Bluetooth or wireless even.
Cheers
I don't believe so, but I'll have a look around.
You'll run into problems if the USB port also supplies power - as any <<USB to wireless to USB>> connection would need a power source at both ends...
Belkin do the 'Belkin F5L009 5-Port Network USB Hub' and Iogear have the 'iogear GUWIP204' which both allow you to connect devices to a hub that then connects wirelessly with your computer. Not sure if it will handle your wheel though
