is this about right for 2 6970 CF
19 Jun 2009
score looks a tad on the low side...
3dmark11 gpu score should be around 10-11.5k depending on our OC.
CPU score will usually drag the P score down for xfire 6970. Unless you are running 5gz+ i7 2600k.
Your score is fine.
Using the settings suggested on the heaven thread, I would expect a score around 2200 averaging around 80-85 fps.
