My Vega64 has been noisy from the moment of Install (not quite 14 days).
It's not the power supply as I've tested it with a friend's superflower 800 psu to rule my psu. Even undervolted at 1400mhz@900mv it makes the buzzing sound.
Basically it's the exact same sound a Fiji makes when under load here,
It's particularly bad in benchmarking, in games when capped to 60fps it's quieter but still kind of noticeable. Turning on speakers or allowing the fan to spin over 2400rpm does drown out the buzz, but I'm not sure if a £460 card should be doing this. As in quiet moments you can hear it
Here's fire strike which is worse due to current draw.
Here's dishonored 2.
