- 28 Oct 2010
- South east
Is this adapter ok for eyefinity? http://gizmodo.com/5609670/kanex-has-their-own-mini-displayport-to-dual+link-dvi-adapter
Thanks x
Thanks x
http://www.overclockers.co.uk/showproduct.php?prodid=CB-047-OK&groupid=701&catid=48&subcat=1757
I'm not sure you allowed to post that link, this should work ok.
gizmodos main business isnt to sell you items. They review tech and steal prototype iPhones![]()
That one's passive, it won't work.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-250-SP&groupid=701&catid=56&subcat=1502
But if you need one with Mini DP then you might have to look around elsewhere.
That passive adapter is only for use with the 5870 eyefinity edition AFAIK, so if you have a different graphics card then it won't work - you need an active one.
As for the apple dual link, it should work - but its rather expensive. Are you certain you need the bandwidth of dual link? For most resolutions (1920x1200@60Hz or less) single link is sufficient and these adapter are much cheaper (like the one Orcvader linked to).
