Just done a few speedtests as have been somewhat unable to browse either the BBC or MS sites both of which contain info I want
I got these results:
27/5/2006:
TIME: 19:35
Speedtest.bbmax.co.uk Results:
DOWN: 1802Kbps (1.8Mb)
UP: 261Kbps (0.3Mb)
TIME: 19:37
ADSLGuide Speedtest Results:
DOWN: 1951.4Kbps (1.9Mb)
UP: 371.9Kbps (0.4Mb)
TIME: 19:44
BT Speedtester Results:
DOWN: 5289Kbps
UP: N/A
Would this indicate some sort of ISP problem rather than a line problem? I am using a Netgear DG834GT (heard these aren't so good - is this true?) with the following current stats: (Firmware Version V1.02.04)
As you can see the BT Speedtest gives a massively increased figure but I'm getting performance nowhere near that. What next?
27/5/2006:
TIME: 19:35
UP: 261Kbps (0.3Mb)
TIME: 19:37
TIME: 19:44
DOWN: 5289Kbps
UP: N/A
Code:
ADSL Link Downstream Upstream
Connection Speed 8064 kbps 448 kbps
Line Attenuation 32.0 db 17.0 db
Noise Margin 5.4 db 23.0 db
