Is this build OK for under 400?
It's fine, but in all honesty I'd get the i5-750 over the 660. Cheaper too. Unless you are going for the 5GHz overclock with it.
The OEM version is just the CPU in some anti-static with OcUK packaging. The retail version has all the packaging and all the instructions.
As your getting a different cooler save the £18!
