Is this build ready to go? Sorry if wrong place to post
25 Dec 2020
Hope I'm using forums right. Is this PC ready to go? I don't want it to explode because of a bad fan or anything. Tried my very best to do some actual research around each thing. Plan to buy a second of the SSD to RAID at some point.
I'll mainly just play modded Minecraft on it. Please let me know
Here is a link, idk if it works
https://www.overclockers.co.uk/ocuk...M3u!4bPkN3u~4bPkO3u~)bPkP3u~WbPkQ3u_xbPkR3u_W
Here is a list:
Case
Aerocool Tomahawk FAW RGB Mid-Tower Case - Black Window
CPU
Intel Core i5-10600K 4.10GHz (Comet Lake) Socket LGA1200 Processor - Retail
CPU Cooler
Alpenföhn Alpenfohn Ben Nevis Advanced CPU Cooler - 130mm
Motherboard
MSI MAG B460 TOMAHAWK (Socket LGA 1200) DDR4 ATX Motherboard
Memory
Team Group Vulcan Z T-Force 16GB (2x8GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit - Grey
Graphics Card
Asus Radeon RX 5500 XT Dual EVO OC 8192MB GDDR6 PCI-Express Graphics Card
M.2 Solid State Drive 1 (Primary Drive If Selected)
WD Blue SN550 500GB NVME M.2 2280 PCIe Gen3 Solid State Drive (S500G2B0C)
Mechanical Hard Drive 1
Seagate BarraCuda 1TB 7200RPM SATA 64MB Cache Hard Drive - *System Stock*
Power Supply
Kolink Classic Power 600W 80 Plus Bronze Power Supply
Operating System
Microsoft Windows 10 Home Advanced - Systems
Build Time
OcUK Professional Standard Build Systems - Dispatched in approx 10-15 working days
Looks nice, I would be tempted to pay alittle bit more to get a big mesh fronted case for better airflow to help your cpu cooler and 5700 xt, but that build seems fine
Thank you very much! :)
Any shortcomings the build will have, do you know? Like will it suffer a lot in graphically-demanding games or reaching high framerates? Not my primary goal of the PC but would be nice to know
Getting a reputable brand of a good quality is an often overlooked part of a build, the bronze, silver, gold, platinum ratings are for the efficiency of the psu. Means they will provide more reliable power at different loads. I go for Gold minimum in all my builds, and have only had 1 random fail on a psu that was under warranty. Assuming you won't be overclocking and doing things that draw masses of power for your system a 500-600W is more than adequate for your uses. But I always look at warranty, a good warranty is worth it's weight in gold, especially if you get a replacement if it ever fails.
What are things that draw masses of power from my system? Any games I won't be able to play? Maybe Overwatch?
Only if you're going to do crazy things like overclocking, or installing power hungry gpus like the rtx 3080 which I am guessing you won't. for example 5500xt draws 130W, 5700xt draws 250W, and a rtx 3090 draws 370W
5500 XT may start to suffer with the new games at high/max settings, but if you're willing to turn down some options you should be fine for casual gaming. Overwatch will be fine with a 5500xt it isn't a graphically demanding game. Enjoy your pc, it will do everything you want it to do, don't get caught up upgrading for features/performance you won't use
