- 29 Aug 2010
- Cornwall
I'm planning to use some old PC bits (inc. ATX motherboard) to make a HTPC.
I know it's not a small case, but is it any good? Is there anything better that can fit an ATX motherboard?
Just wondering if anyone had used this case?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-020-OP
Any problems with the case?
Is the PSU any good or should it be replaced?
Thanks.
Thanks.
