Is this correct mem speed?
16 Nov 2006
Cardiff
just checking pc on CPU-Z and i was looking at the memory speeds, and i'm certain that its wrong
running 1 gig ddr2 4200 generic ram
running frequency = 245.6 MHz
now if i understand this correctly, that should be 266/7 MHz to be running at 533Mhz ddr ?
what could be causing my ram to be running slower ??
Sounds like your RAM divider is on 4:5 or thereabouts.
And again, the 20mhz will make no difference.
ok thanks for the info, not really sure what the ram divider is and how to change it though :(
