Is this going to be enough power???
29 Aug 2012
Hi all is the below powerful enough for a semi future proof PC rig. I've been given the specs from a friend my budget is £1000 I an plan to play things like bf4 on ultra at 1080p with the most fps I can get
Intel Core i5 4670K Processor overclocked to up to 4.2GHz
Corsair H75 CPU Cooler
Gigabyte M5 Sniper Motherboard
Palit Jetstream NVIDIA GeForce GTX 770 4GB Graphics Card
8GB PC3-12800 1600MHz DDR3 Memory
1000GB SATA 7200rpm Hard Disk
Fractal Design Integral 650W PSU
Onboard High Definition Audio
Windows 8.1 64bit
That sounds a lot like a pre-build spec.. Are you sure your mate is building it for you?
I'd personally go for a 280X over the GTX 770.
I have Idea when it comes to parts he emailed me earlier with that I just copied and pasted it on here to see if it adds up an to get your thoughts
I wouldn't bother going for any palit card.
And gtx770 won't benefit much from that 4gb vram.
I'd rather buy a good quality r9 280x, as it was already suggested here.
Better bang for buck, definetely.
Same goes for power supply.
When it comes to power supplies its bad and sometimes costly to cut corners.
You'd do much better to ask here for a build spec. With 1000£ budget you can have a decent one.
Ps. Checked Lee's post and it looks much better than your friend's build.
Looks good, though the water cooler could be swapped for air to save money also?
I did a quick search on the specs it is the same parts as a pre build on a competitor site... I say mate it's a lad I knew from school I know builds pcs.
You were bang on, Doomedspeed. I've found the exact build (exact words) on a company's website and cost inc. VAT is £1000. Won't link as it's a competitor.
Strange your friend is charging the exact same price as that company for the exact same thing lol.
Lol, exactly - why would he charge the same price, attention perhaps? Well at least you have your answer as to whether you want it or not xD
