is this going to be enough
A genuine 700 watt PSU is enough for that spec, yes, but I can't see anywhere what the PSU is and quality matters.
I'd recommend an upgrade/swap to a known decent PSU from an established brand, with a 10 year warranty (like the Phanteks AMP 750, which is built by Seasonic).
That said, if the PSU doesn't work or blows up, that is not your problem, OCUK are responsible for replacing faulty parts (part of why you pay extra for a pre-build after all).
I've had a quick look & there's not a way to pick a PSU of your choice on any of the PC systems. It does tell you what make & model it is on the more expensive systems, but if it doesn't tell you then I would assume its Kolink.
If that was me then I'd phone them up & ask them if they could install the PSU of my choice in my build. I don't think that's too unreasonable.
Yeah you never want to skimp out on the PSU, it is one of the most important parts of your build, all brands can have crappy PSU units and good PSU units, make sure to check reviews on the particular model of PSU that you are going to buy if you are going to install your own.
