is this my maximum
16 Feb 2012
mob - z77-d3h
i3570k
4.4ghz
vcore - 1.275 can't get it lower without bsod
max temp - 80c - 10x passes on max with ibt
is this max safe limit or could I push higher temp wise
also shod I touch cpu vtt or pll or leave them on auto
many thanks guys ans gals
Only you can decide how far to push, based on how long you plan to keep the PC and how often it's used. I'd stop at 80c under max stress myself tho.
VTT doesn't need to be touched unless you overclock the memory
You can lower PLL to 1.71 to reduce temps slightly, but it doesn't seem to have any impact during normal use. I keep mine at 1.8v to avoid any stability issues.
