is this noise normal?
26 Aug 2004
South Wales
when i hold down the power off/on button on the pc to turn it off i hear like this squeak noise coming from the graphics card as it turns off.. never got that with my 6800 GT? only just plugged it in.
when the power connector to the graphics card has no power it makes a loud squeaking noise for a warning, it mighht just me that the power to graphics is cut out before the motherboard
it only does it when i turn off the PC, its one squeak.
yea, when you turn it off it might cut the power from 12v rails before then mobo so it still gets power from mobo for a second but loses power from the connectors you plug into back
oh ok, so nothing is wrong then.. a tad annoying when shutting down but at least it is not a problem.
