hey guys i made a post earlier but im still thinking about changing a few things in the pc specs you came up with.
Is this ok to run bad company 2 etc on high settings? will be running on a 1440x900 monitor!
Corsair VX CMPSU-550VXUK 550W Power Supply (PSU)
Gigabyte GA-880GM-UD2H AMD 880G (Socket AM3) microATX DDR3 Motherboard (can i save any money here or stick with this?)
HAF 912 case or coolermaster scout ( i really like the 922 but for the extra £20 i dont see any huge improvements against the 912, as i said im a first time builder dont require lots of hdds or anything)
Phenom x4 955 Cpu (can i go with athlon? or do you reccomend i stay with phenom?)
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card (The thing im getting confused with on this is that it require 2 6pin connections?, does this psu work with this gfx?, should i stay with nvidia or go ATI?
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz
As for OS my friend has covered that, Optical drive i have and i have a 1tb hdd all set and ready to drop in.
Does this seem a decent spec for running games on med to high settings at 1440x900?
thanks guys getting very confused with this :s
