- 9 Dec 2008
Some of you have probably used this Zalman cooler. In the pic it is installed on a P4. Another roughly similar Zalman cooler that was for P4 AND Athlon installed on to P4's exactly like THIS one does. Please jump to the second pic.
Here you see the bolt-arm. I know that the OTHER Zalman cooler that I mentioned used adapters to allow those metal arms to be bolted on to an Athlon socket. My question is does THIS Zalman cooler come with another metal arm that has the bolt holes slightly further out OR are they already in the right position for installing on to an Athlon socket?
If you have used the above Zalman cooler but are confused what I'm asking please say so. I can clarify. I can get Zalman adapter brackets for Athlon sockets, but I don't know if those bolt holes will be in the right spot.
Thanks!
edit: By "Athlon socket", I mean socket 462 or socket A (I don't remember which is the proper term).
Thanks!
