Hello Overclocker Family,
I have meticulously sifted through each and every component and attempted to build my dream PC. I do have some questions which would definitely put my mind at ease when it comes to hitting order if anyone can help, it would be appreciated.
I have built this spec on another site so if anyone official was to look at this they may be like, we don't sell this or something along them lines, I am simply trying to piece it together and haven't shopped around.
Things to note:
- My budget is £4,000 with a little bit of wiggle room.
- I want to synchronise as much of the RGB controls as possible so I don't have to have a multiple controllers or applications handling them.
- I plan on streaming my gameplay of Fortnite and Rocket League using my Elgato 60S+ USB Capture Card combined with OBS. I also want to be able to think about video editing, playing VR games, 4K games and be ready for 8K games, finally it would be amazing if I could mine for crypto in the PC's downtime (don't hate me I haven't done it yet!).
- The case in my opinion is super beautiful, absolutely love it. I really want to build my PC around it.
Here is the build:
Case - CoolerMaster MasterCase H500M Gaming Case (LS)
Custom Liquid Cooling Kit - Liquid Series RGB Mid Kit - Corsair Hydro X
Tubing - Clear Hardline PETG Tubing (Bent/Metallic Fittings)
Graphics Card Cooling - GPU Water Block - For One Graphics Card!
Coolant Colour - EK-CryoFuel Purple
LED Lighting - 2 x 50cm RGB LED Strip
Overclocked CPU - Overclocked AMD Ryzen 9 5950X 16 Core (3.4GHz @ up to 4.65GHz)
Motherboard - ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) - RGB Ready!
Memory (RAM) - 32GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 16GB)
Graphics Card - 10GB ASUS ROG STRIX GEFORCE RTX 3080 - HDMI, DP (Pre-Order Only)
1st Storage Drive - 1TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
2nd Storage Drive - 1TB Samsung 870 QVO 2.5" SSD, SATA 6Gb/s (up to 560MB/sR | 530MB/sW)
M.2 SSD Drive - 500GB SAMSUNG 980 PRO M.2, PCIe NVMe (up to 6900MB/R, 5000MB/W)
RAID - RAID 0 (STRIPED VOLUME - 2 x same size & model HDD / SSD)
Power Supply - CORSAIR 850W RMx SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Power Cable - 1 x 1 Metre UK Power Cable (Kettle Lead)
Braided Power Supply Cables - CORSAIR Premium Individually Sleeved PSU Cable Kit Pro - Black
Sound Card - Asus Xonar AE 7.1-Channel Gaming Audio Card
Other - Windows 10 Pro, full insurance cover for 3 years, other things nobody cares about.
Price - £4,075.00
Questions I have regarding the build (I have numbered them so you can reply directly without having to quote them in your responses):
1) Topic: Restricted water cooling options due to the size of the case selected.
The water cooling options are restricted to:
- Liquid Series RGB Mid Kit - EK
Question: Which of these performs better, I think the only difference I have been able to find is the sizing of the tubes. Is this a cosmetic difference or will this effect the cooling performance, amount of energy required to pump the fluid through them.
2) Topic: Restricted water cooling options ability to cool such a powerful computer.
Question: As the parts I will be using are very high spec, will the Liquid Series RGB Mid Kit's be up to the task?
3) Topic: RGB Strip lighting within the CoolerMaster MasterCase H500M Gaming Case.
Question: I have selected two RGB lighting strips, assuming there is only dedicated space for two strips, is my assumption correct?
4) Topic: The CoolerMaster MasterCase H500M Gaming Case can support up to 3 additional fan(s). I have added the Liquid Series RGB Mid Kit - Corsair Hydro X that comes with a 360mm radiator and quoting from the more info specs 'Up to 4x Corsair RGB Fans'.
Question:
a) Will the radiator be situated at the top of the case with the fans attached; occupying the 3 additional fan slots?
b) Also, the 4th Corsair RGB Fan that comes in the cooling kit, could I replace the plain black fan located at the rear of the PC Case?
5) Topic: Selecting the right RAM for the ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) Motherboard.
Not knowing if the ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) Motherboard's RAM slots are bi-channel or quad-channel.
Question:
a) Am I best getting 4 x 8gb or 2 x 16gb sticks of RAM?
b) Should swap the 32GB Corsair VENGEANCE RGB PRO DDR4 3600MHz (2 x 16GB) RAM for the lower MHz 32GB Corsair VENGEANCE DDR4 3200MHz (4 x 8GB) RAM to occupy all four channels?
6) Topic: Braided Power Supply Cables.
I wanted to have purple braided cables, but they are not available in that colour.
Question: Are braided cables safer, offer a better quality power transfer, noticeably different to standard cables when they are simply black braided cables, do they come with some kind of warranty or protection standard cables would not offer? Or, are they just cosmetic!
7) Topic: Choosing the right sound card for my intended use.
I plan to stream my gameplay, I play using Nuraphone headphones using their gaming microphone cable, I have a Rode microphone too, I listen to music 24/7 on (currently 5.1 but will potentially upgrade to 7.1) surround sound speakers.
Question: Has the Asus Xonar AE 7.1-Channel Gaming Audio Card got me covered / should I be using the stock sound from the ASUS® CROSSHAIR VIII HERO WIFI (DDR4, PCIe 4.0, CrossFireX/SLI) / or should I be getting a better sound card?
8) Topic: HD / SSD / m.2 Partitions
I want to make the best use of my m.2 drive. The things I will be using the most on the computer are:
- Booting the PC.
- Google Chrome.
- OBS.
- Fortnite.
- Rocket League.
- Spotify.
- Adobe Photoshop & Illustrator, editting software.
Question: What should I specify the partitions to be to make these all have priority and ability to sit on the m.2 for quickest reads and writes?
I would really appreciate if you could respond using a numbered system as I am not a wizard when it comes to the naming structure of all of the PC components, so if you could copy and paste this template below and respond to the questions you can help me with accordingly it would help me massively:
My experience with these components: Owned / Tested & Reviewed / Watched Reviews / Looked at the Specs / I just know better than you - deal with it!
Q1) Answer
Q2) ...
Q3) ...
Q4 - a) ...
Q4 - b) ...
Q5 - a) ...
Q5 - b) ...
Q6) ...
Q7) ...
Q8) ...
Appreciate this is a very long post, thank you all for taking the time.
Thanks, Doops.
Things to note:
Here is the build:
Price - £4,075.00
Question:
Question:
- Booting the PC.
- Google Chrome.
- OBS.
- Fortnite.
- Rocket League.
- Spotify.
Q1) Answer
Q2) ...
Q3) ...
Q4 - a) ...
Q4 - b) ...
Q5 - a) ...
Q5 - b) ...
Q6) ...
Q7) ...
Q8) ...
Thanks, Doops.
