Is this possible (handbrake/winter issue) ?
Permabanned
3 Dec 2022
Up North
I've never had a problem like this before and can't decide if the freezing weather is the cause or if an enemy/vandal has tampered with my vehicle last night.
It's a van with big wheel arches so it wouldn't be hard for someone to slide their head and an arm behind the rear wheels and mess with the handbrake cables/caliper.
I went shopping last night and handbrake was fine. Heard the usual 5-6 clicks that's normal when you pull up a handbrake lever and park. Drove home and handbrake still fine. Parked up again and heard the usual 5-6 clicks. This morning though, there's loads of play in the handbrake lever and only 1 "click" sound right at the top position. The handbrake lever is literally flapping around with no tension at all.
Is the hand brake actually releasing when you let it off? If the rubber boot at the end of the cable is in poor condition moisture can get into the cable, which in this weather will freeze and can cause the cable to stick.
I'll have to check that later. I don't know if the rear parking brakes are stuck on now or if they're not even engaging. I always leave vehicles in 1st gear when I park so it didn't even cross my mind to check if the van will roll in neutral. Good advice that pal. Kudos for the heads up ;)
If the rear parking brakes are stuck on or the cables seized with ice/moisture do you think soaking the rear assembly with WD40 would help or do I need to get booked into a garage for a proper repair job ?
Seems strange that it happened overnight and not when I parked and pulled the lever the last time :confused:
This it why it’s a good idea to park up in gear and turn the wheel in toward the curb if on a hill too. Handbrake cables can and do fail unexpectedly.
Either way it’s going to need to be looked at by someone to find out for sure what is going on.
That's very true but novice drivers also need to remember that you only turn the wheels towards the kerb if you're parked on a hill and facing forward down the hill. If you're parked on a hill facing forward up the hill you need to turn the wheels away from the kerb.
Never leave a vehicle in neutral. Always engage 1st gear.
Not really as things often work fine right up until the time they fail.
Does Google reveal whether this failure is common on your make and model of van?
I haven't googled but I've had 4 of these vans between now and 2011 and know the model quite well. They're good workhorses that generally don't have any mechanical issues until about 100k-150k when clutches start slipping (even assuming you treated the clutch gently pre 100k and mostly did motorway miles).
Given the weather, I'd put money on the cables having frozen. That's why there's no tension at the handle end - because the cable is being held still at the brake end.
Can you tell whether the handbrake is stuck on by how the van is acting? Slightly harder to pull away? Slowing down on its own from a crawl?
I'm going to externally fully spray the rear brake assembly tomorrow with WD40 (obvs not the discs/calipers though!) and then do a few laps around my local area with plenty of parking attempts. I've only used this van lately for daily trips to the supermarket and it's only a 5 minute journey on a flat road with 2 sets of traffic lights so I haven't gone above 20-30mph to notice any lag in the power/acceleration.
I'll put it on a steep slope tomorrow in neutral and see what happens.
If the cable is frozen, it'll almost definitely free up shortly into a drive, as the heat from the brakes travels through the cable and unfreezes them.
Of course, in the intervening period, you'll be driving along with your handbrake partially on. So it might not be the safest or healthiest thing ever. So this by no means should be considered advice. :D
Heavy snow has thrown a spanner in the works this morning so I can't go out for a drive to try and diagnose the handbrake problem :mad:
Thanks for the advice though guys. You've given me stuff to think about and some ideas to try before spending money on repairs that I can't afford at the moment.
Sounds like a perfect opportunity to find an empty car park and test it with some handbrake turns :D
