- 24 Jul 2009
I've been trying this today and I'm not sure it is.
I've been given an EE Brightbox router and will use this as a 2nd access point upstairs (currently use a BT HH5 to do this). I have my main HH5 router downstairs that handles all DHCP and is where the connection comes into. I then have this connected via Ethernet to the 2nd EE router upstairs.
I plan to replace the 2nd HH5 with the EE router due to being able to create a guest network by creating a 2nd SSID and 2nd VLAN within the EE router settings which will be 192.168.2.x. My main HH5 router settings are 192.168.1.x.
However I have encountered a problem as the 2nd SSID and VLAN doesn't have an Internet connection. I can connect to it fine but not view web pages etc. Is this problem caused by the fact that the EE router isn't connected to the Internet directly? If so, is there a way to solve this without using the EE router as the main router?
Thanks.
Thanks.
