Hi All,
I've been posting the odd question here and there recently, I'm trying to install Linux with Vista (dual boot) at the moment because I want to learn how to use it before building a media server (to serve video, music and photos to my PS3).
The reason for the post is find out if what I want to do is definitely possible.
At a minimum this is what I would like to be able to to do:
Ideally this is what I'd like to do, but this is much more complicated:
I'd also be interested in converting most of my DVD collection as well, so I can store my DVDs away in the loft or something.
If it helps at all the Newsgroup I'm subscribed to has the ability to save searches as an RSS feed, the only problem being trying to narrow it down to one result (as I'm sure you can imagine).
If any of this is possible, I'd be very grateful for any direction/help provided.
- Bung a video or a few videos into an folder, lets call it "Input".
- Then have a a video converter, that would be monitoring the "Input" folder every so often, convert it to a specified format (i.e. the most ideal format to stream to the PS3). And then put the converted folder into an "Output" folder.
- The "Output" folder will be the source folder for the media streaming software, so it would appear on my PS3 (I've read MediaTomb is probably the way to go?)
- Have my media server connect to the internet and, according to a manually create schedule, download a video from the News group I'm subscribed to.
- Once downloaded, do all the stuff as above.
- I'd also like to Tag the videos (like you can in TVersity, to make it easier to navigate on the PS3), the tag could be preset in the schedule.
