Is this possible?
16 Oct 2007
UK
House 1
House 2
House 3
Each has it's own ADSL, with router.
But I want to give 2 & 3 access to a file server in 1.
How do I do this so 2 & 3 still continue to use their router for internet?
Thanks chief.
I will look into that, quick question..
Is that router make/model dependant? Do most have the functionality?
You can either do hardware based (better) or software (cheaper) using Hamachi for example.
Most routers should have basic vpn ability, even a lowly DG834GT (using the 1.02.19 fw). It's really more a question of budget.
